There seams to be a two stage attack on this paint job.......
1st stage is to find a rattle can that near matched the paint work, then light flat the peeling, bubbling, rusty spots and spray with can.
This will give you time to drive the car till stage 2.
2nd stage is when you have time,( read money, time, inclination, holiday....) plan a nice long space of your life, and heat gun and scraper all the paint off, and start again.
Sad, but there in no quick fix here, its all got to go, to be put back on again the right way
My Bug - New peekchas
- Been thanked: 541 times
Re: My Bug - New peekchas
- MarshallGTi
- Camshaft
- Has thanked: 7 times
- Been thanked: 11 times
@Herman, i know it'll be a b1tch to fix and theres no quick way round it. was thinking instead of fixing the bad bits with paint i would try sanding them back, then rust converter, the primer, then try blend the primer bits in like faux patina.
@vader, it wasnt even a very abrasive polish. i tried a spot on my old mans kombi and my moms golf and the colour didnt come off either. i understand polish works by removing some clear coat to get it levels with the lowest part of the swirl marks etc, but there should be decent thickness of cleear before removing the actual paint right?
Ryan Marshall
dont leave the primer exposed. As far as I know it absorbs water and sends it directly to the metal to start the oxidation process... Paint protects primer
- MarshallGTi
- Camshaft
learn something new every day...Tony Z wrote:dont leave the primer exposed. As far as I know it absorbs water and sends it directly to the metal to start the oxidation process... Paint protects primer
they dont by some lucky chance make decent rattle can clear?
Ryan Marshall
YES ... Rusto-len make a good clear..MarshallGTi wrote:learn something new every day...Tony Z wrote:dont leave the primer exposed. As far as I know it absorbs water and sends it directly to the metal to start the oxidation process... Paint protects primer
- MarshallGTi
- Camshaft
Million dollar question, condenser failed (again) and bolt on the distributor clamp stripped. Old man tried drilling the bolt out and took some meat out of the clamp with it. She's running again but I don't know if I trust it to make it to Angela's and back
Sent from my Nokia 3310 using Tapatalk
Ryan Marshall
- MarshallGTi
- Camshaft
just for the record, i'm selling the beetle. if anyone is interested please shoot me a pm. i'm having no luck with it on bumtree. swaps also considered, preferably of the 2-wheeled variety.
Ryan Marshall
- beetle786
- Camshaft
- What model do you have?: 1968 + 1303
like the steering wheel on the beetle .I've got a sp steering to swop .MarshallGTi wrote:just for the record, i'm selling the beetle. if anyone is interested please shoot me a pm. i'm having no luck with it on bumtree. swaps also considered, preferably of the 2-wheeled variety.
