Nearly forgot I bought this from Britania tow bars its a lighter for the stove & its long so you don't burn your fingers. Its a must have accessory for the wife.
Took off my mains hook up point & rewired it with UK (european harmonized) 230V basec twin & earth cable. This is coloured Brown Live (white or hot in the USA) & Blue neutral (black in the USA) this will run straight to a fuse board comprising of 2 MCB's (Minature Circuit Breakers) both MCB's will be 16A one will feed the mains chargeing unit the other the 230V 3 pin socket outllet & an RCD (Residual Current Device) ratted to a trip of 30mA. I sleaved the bare copper core with yellow/green sleaving this is my earth or CPC (Circuit Protective Conductor) this is manditory in the UK to meet the current 17th eddition wiring regs.
The supply in the UK is 50Hz (it switches 50 times per second) in the USA its 60Hz. also our Neutral is the same potential as the earth but our Live has a potential of 230V so if you get an electric shock its a big one, thats why an RCD must be used. In the USA the earth is centre tapped so the live & neutral both have a 55V potential (55 + 55 = 110V) so the risk of death from electric shock is much smaller.
Anyway here are a few pics:-
Before:-
After:-
Painted the outside Satin Black the centre will be covered with a silver sticker reading as follows:-
DELTA SIXINDUSTRIES
N.Hollywood, Calf. 91601-U.S.A.
Waterproof Motor Base Cover
Catalogue # DS-100
RECREATIONAL VEHICLES ONLY
THIS CONNECTION IS FOR 3 WIRE
230vOLT ac 50 hZ (cYCLES)
16amp SOURCE
My leasure battery has no connection to the chassis of the vehicle so the split charge circuit won't work so I bought this:-
You could see te copper so I sleaved it to make it look a bit nicer with heat shrink:-
I also bought a 12V fuse box so I can fuse each circuit:-
