Riekert
Camshaft
Posts: 819 Joined: Mon Feb 13, 2012 9:50 pm
Has thanked: 111 times
Been thanked: 23 times
Post
by Riekert » Mon Mar 11, 2013 3:27 pm
Ron&Gill wrote: O, you're in Sandbaai... Gill's aunt lives in Sandbaai.
Yeah. Work in hermanus and live in sandbaai
Riekert
Camshaft
Post
by Riekert » Tue Mar 12, 2013 10:22 pm
Hey guys. Need some help... How can I rewire a 12v alternator setup to work with a 12v generator?
Riekert
Camshaft
Post
by Riekert » Tue Mar 12, 2013 10:25 pm
Oh also any help IDing this motor?
Any help will be awesome. Evetything I can dig up is that its a 1600. But got conflicting info saying its a 1200:???:
Posts: 15009 Joined: Wed Sep 14, 2005 8:33 am
Has thanked: 192 times
Been thanked: 488 times
Post
by Tony Z » Tue Mar 12, 2013 10:38 pm
thats not a 1200
look for info on the AD letters. SF is a South African letter stamp (rebuilt I think)
Riekert
Camshaft
Post
by Riekert » Tue Mar 12, 2013 11:10 pm
Thanx tony. Most of the info I get on the AD number tells me its a 1600. But the guy who I bought it from said it was a 1200/1300. So really confused
This is what I got from the samba :
"Type 2 engine
AD 1971-73 1600cc 50bhp DIN. Non-USA."
So it should technically be a 1600 bus engine?
buggyfan
Long Block
Posts: 2979 Joined: Wed Mar 12, 2008 2:26 am
Has thanked: 95 times
Been thanked: 87 times
Post
by buggyfan » Wed Mar 13, 2013 1:10 am
Riekert wrote: Hey guys. Need some help... How can I rewire a 12v alternator setup to work with a 12v generator?
do you want to convert from a 12v generator to a 12v alternator????
Riekert
Camshaft
Post
by Riekert » Wed Mar 13, 2013 7:05 am
buggyfan wrote: Riekert wrote: Hey guys. Need some help... How can I rewire a 12v alternator setup to work with a 12v generator?
Nope other way around. Seeing as the beetle is wired for a alternator and I've now put a engine in that has a 12v generator
MarshallGTi
Camshaft
Posts: 883 Joined: Wed Feb 01, 2012 4:16 pm
Has thanked: 7 times
Been thanked: 11 times
Post
by MarshallGTi » Wed Mar 13, 2013 7:38 am
just the wiring on the regulator needs changing i think.
AD is a 1600 beetle motor same as mine.
Post
by Tony Z » Wed Mar 13, 2013 8:28 am
get an alternator. More money you say now, but they are also much more reliable
Riekert
Camshaft
Post
by Riekert » Wed Mar 13, 2013 9:33 am
Thanx guys! Sweet deal on the 1600
hehe. I've got a 1600 twin port that I can rebuild too so yay!
And Thanx will get a alternator then
Riekert
Camshaft
Post
by Riekert » Fri Mar 15, 2013 12:11 am
Swapped the notches rostyles for the beetles now the beetle can almost go for roadworthy. Just need to sort engine and brakes.
Riekert
Camshaft
Post
by Riekert » Sat Mar 16, 2013 5:40 pm
Post
by Tony Z » Sat Mar 16, 2013 5:50 pm
a stock weight engine is easy to get in and out.
1x trolley jack and 4 bricks is all you need.
Drag engine under car into engine bay.
Lift one side by holding onto cylinder head cover
put brick under exhaust.
lift other side, put brick under.
repeat until engine is 2 bricks off ground.
put jack under engine, lift and install.
Now the question... did you put that flywheel back onto that crank?
Flywheel is fkd
crank is fkd - look at the ridges around the dowels (I am not even mentioning the state of the dowel holes).
did you set endfloat properly?
The flywheel probably wasnt torqued down properly in the first place.
Riekert
Camshaft
Post
by Riekert » Sat Mar 16, 2013 6:11 pm
Thanx
New flywheel old crank...
Would it be at all possible to redrill the crank?
Otherwise I'm fooked
Endfloat still seems fine
Posts: 8710 Joined: Mon Feb 07, 2011 8:51 pm
Has thanked: 421 times
Been thanked: 541 times
Post
by retrovan » Sat Mar 16, 2013 6:35 pm
Sorry to say, thats a full engine rebuild, that crank will have to be welded and re-drilled at best
And it will have to come out to do that.
Else you f%$k-up the rest of the engine.
