New to me Fasty
Re: New to me Fasty
I was so Jealous I could not drive the Fasty when Johan took it for a test drive due to my leg but the Wive did and said it drove very nice
Thanks for giving VdubTECH the Business
Re: New to me Fasty
After lowering 2 clicks on the front suspension was the drive not hard or did you change the shocks as well.
Mine is a very hard ride, especially going over bumps or even just turning into the driveway.
Your comments please.
MrT
Has thanked: 22 times
Been thanked: 9 times
Re: New to me Fasty
Post by MrT »
brianj wrote:Now with motor redone (thanks forcecooled) run in, serviced and lowered 2 clicks in the front (thanks vdubtech)....ready to daily drive- when required.
Nice car!
forcecooled
Re: New to me Fasty
Post by forcecooled »
Lovely car Brian,
Very nice colour too, and now you dont have to put the traditional trainwheel in the sparewheel compartment to keep the nose level !
Glad you are happy with your motor, but bear in mind that the most important part of any good build is the preparation, and the machine shop that you used did a very good job there.
Make sure that you use a decent oil there Brian - Like Castrol edge sport 10W60. most service organistions dont use expensive superior type oils when doing servicing unless requested or provided by the ovner.
Wishing you miles of smiles with her !
Bill Noble
brianj
Re: New to me Fasty
Post by brianj »
Thanks folks, going to just enjoy her for a while.
The tyres touch at full lock and when going over bumps at speed or 2 up, but this should go away when I move to lower profile tyres at the front. I did change the shocks.
If I keep the higher profiles at the back it will have to probably go down a notch. We'll see...
Forgot to add that this was done by Pierre's team in 2 days, even with him out of action.
forcecooled
Re: New to me Fasty
Also, ensure that the steering geometry remains in kilter, otherwise the can can become unpleasant to steer.
Sometimes it is required to fit castor shims and longer bolts on the lower front beam to re-instate the self centering function when coming out of a turn
Re: New to me Fasty
Looks sick Brian! Why don't you throw some Sprintstars on there :twisted:
brianj
Re: New to me Fasty
Post by brianj »
the sprintstars are lined up Blitz.... just looking for some 185/55's going cheap. I am not going to refurb them, rather run them ratty.
oil is the Fuchs Titan supersyn 5w50 that I supplied, but I see Pierre is using Fuchs as well.
Will check on the steering Bill, but so far all good..... couldnt resist taking her to work today.
forcecooled
Re: New to me Fasty
Great----
5w50 synthetic sounds like a good grade for modern tight tolerance motors with all the fancy valve control systems that they all seem to have these days.
Clattery old and new aircooled motors with thier large clearances shaky oil pressures and relatively high operating temps
can really do with the added protection a 60 grade type oil.
