- 4agedub
- Has thanked: 4 times
- Been thanked: 13 times
Started playing around with the electronic side today. Now here's my idea:
I'm going to use a 60 -2 trigger on the front crank pulley with a magnetic sensor for the rpm input to the Gotech ecu
The MSD distributor that I'm using now will be taken out and a VW 2,1 distributor will be installed. The chopper plate in the distributor will be modified as to only give out a TDC sensor.
Use the Gotech PRO X computer and run it full sequential so one injector will trigger at a time. The spark will be distributed with four coils. One for each cylinder.
I will use four injectors for the petrol and four for methanol injection to cool down the combustion chamber at high boost.
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
- 4agedub
Next thing I also want to do on my beetle is change a bit on the body again... something like a little wing on the back maybe. Any suggestions?
I def want to tint the windows as the roll cage gives it all away
- Been thanked: 98 times
I'm sure ther is no need for tinting, your bug will be up the road so quick the dudes will not even have a chance to look at it's backside never mind inside.
BTW what have you done to your box or what are your plans to keep all that HP where it should be?
- 4agedub
I'm running a 1300 gearbox with the rough gears. Standard syncros. The diff is locked. So the box is almost stock standard.
I've used this specific gearbox for very long now and I've never broken anything in it... and believe me I drive her like a hooligan. Launching at 6000rpm with bf drag tires.
- 4agedub
Nobody want's to dice me at the robots when they see the roll cage... except for the super bikes, but the still give me a hiding.I'm sure ther is no need for tinting
With the turbo setup they can come
Its Xmas in July>>>> almost anyway
whoo hoo, let the games begin.
I look forward to all the pics and jealousy your going to cause
