4agedub
Been thanked: 13 times
Post by 4agedub »
Hi everyone.
About a year ago I finished building my current type 1 engine. 2180cc, EMPI ally block, Scat 78mm crank, Carillo rods, Mahle 94mm pistons etc etc.
The engine runs great, but I still need more :twisted: The best so far was a 14.1 1/4 mile @ 149km/h @ wesbank on a prepped track. And a 1:18 @ zwartkops around the circuit.
So now she's gonna get the whole turbo treatment. :twisted: This thread might take a while as I'm buying parts according to my budget.
First item I got:
CB performance 044 super mag heads. (I'll take some pics tonight and post them). These babies look awesome. Combustion chamber size 65cc, so with 1,2mm deck height the compression will be 8.5:1. Which is what I want.
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
Has thanked: 36 times
Been thanked: 50 times
Post by flatfourfan »
awesome, be sure to post TONNES of pics......the best my 1.5 VTEC ever did down westbank was 16.8.
Niiiiiiiiiiiiiice.
4agedub
Post by 4agedub »
Here's a pic of the head
The heads have got 42 and 37mm stainless valves and a 12mm relocated spark plug. Double valve springs and cromoly retainers.
The heads are currently unported, that I do need to sort out.
4agedub
Post by 4agedub »
Oh almost forgot, the new cam is a Engle TCS-20. Engle 120: TCS-20 294 deg advertised .435 lift(in) 112 lobe center 284 deg advertised .430 lift(ex) 112 lobe, Turbo Drag race only/large cc-low compression
Jay24
Post by Jay24 »
do you have a msn Address i need some pointers on the Body specs i am building a drag beetle !!!
stuff like Rolecage and supports and suspention the exstras you know
4agedub
Post by 4agedub »
Yes, I got msn. My msn addy is info AT gotech.co.za
Jay24
Post by Jay24 »
just add me accept me i am Jerasmus@realpeople.co.za
do you work for Gotech cause if you do i might get alot of order for you from The lovely city of East london !
Lovely car 4age!!! My brother and I were admiring it at Zwartkops that one time
Good luck with the project, give us lots and lots of pictures...
4agedub
Post by 4agedub »
Added to msn. :)
Thanks Blitzkrieg, will post some pics soon
Can I get a ride in it sometime :wink: we can post the video for all to see here 8)
4agedub
Post by 4agedub »
Cool, will do when she's done. Remember to bring some spare undies
Looking good 4age. sounds like a beast is going to emerge....hmm good
BTW, spark plug is in stock position as far as I know
And yes, they are great heads
4agedub
Post by 4agedub »
:D
Just ordered myself some parts on summit racing from the states... (just don't tell my wife :wink: )
Here's what I ordered:
4x 420cc Edelbrock fuel injectors. I will use these as my primary injectors and my current 310cc injectors for the methanol injection
8x Special ngk spark plugs for the CB heads. The CB heads use 12mm spark plugs and not normal 14mm
1x Turbo heat shield. This shield goes onto the turbo exhaust housing to keep away the heat from the compressor side.
1x Turbonetics Raptor blow off valve to keep the turbo happy and make that nice "whooosh" sound :wink:
1x Turbonetics T3/T4 turbo. Part number TNT-11025. T04e compressor housing with a .48 exhaust housing just like the doctor prescribed. This turbo is matched perfect for 10psi boost and will handle the 7000rpm limit of the engine.
1x Oil drain flange and oil inlet flange to supply the turbo's bearing with some lube
1x Turbonetics evolution dump valve to keep the turbo on 7psi for low boost and 10psi for medium boost and 16psi for racing those gt3 porsches.
Whell, that's all for tonight folks. My parts should be landing on the 30th of this month. As soon as it lands I will take some pics.
By then I better have a good excuse when the wife looks at my credit card statement :?
4agedub
Post by 4agedub »
Tony
You might be right about the spark plug location.
When I bought the heads I was told that on these heads the plugs are relocated, thus redrilled in 12mm.
I'll take some pics of the heads tonight and post them tomorrow. Almost felt like sleeping with them under my pillow. They are just gorgeous. :)
I know, I got 2 pairs.... hehehehehe
Its a stock based casting, just drilled smaller. But what they dont advertise is that the vlaves open at a different angle to the stock 040 and 041 heads - the same angle used on the big race heads (superflos...) making them more centre line and more efficient.... found this out from the germans (I wonder if CB knows)
I am actually looking for various shots of the stock head to compare to my heads that I have done.
I love the shopping list - youre making me dislike this boat even more now and want to come home and play with my toy car.....
