Mild 1600TP Turbo engine
Bratjie
What model do you have?: 74
Facebook: https://www.facebook.com/juan.buter
Has thanked: 3 times
Re: Mild 1600TP Turbo engine
Post by Bratjie »
Ok so the turbo build is definately on the back burner for now, I have 4 guys waiting on recon engines and I had to part with my turbo project engine to help another fellow out. That really suck's :jerkoff: , but I'm sure to be on track soon :D
Esté robusto, ser fuerte!!!!
73 Beetle project
riaanj
Been thanked: 41 times
Post by riaanj »
4agedub wrote:We've done a couple of 1600 tp turbo beetles before. The best turbo so far for that application is from a 1.9tdi vw.
Just a question, if that works, will a turbo from a Hilux 3.0l KZ-Te work on a 2.0l aircooled combi motor? :?:
'Cause as luck would have it I have a Hilux turbo and a 2.0l combi motor here and have been toying with the idea of trying a turbo conversion..
Just keep on BUGGIN'
T6 Ranger 2.2TDCi D/Cab
307E Anglia panel-van
Honda CBR600RR
Honda CBR600F4
Bratjie
Post by Bratjie »
Back on track again!!! :D
So I've spent the last few weeks just prepping the car, fixing nick's and scratches, tried my hand in fixing the front fibre spoiler and it came out good, finished the spray job last night and waiting a few day's before I can flat and polish. Casing has been done and just popped it in the acid bath to clean properly, heads have been ported going back to engineering to fit new guides. Still waiting on the Empi 1.25:1 rocker set ordered, should be here by weekend. Front disc's fitted and castor shims too, so she should handle a little better. Sway bar is next on the list,
Need to find someone close to balance crank, flywheel, rods & pistons, and as the engineering shop have "misplaced" :roll: my stock valves I might as well look for a set of stainless ones.
Just wish I could take a few days leave, it's just taking too damn long to get everything done :cry:
73 Beetle project
justin
What model do you have?: AeroVee
Post by justin »
Bratjie wrote:Need to find someone close to balance crank, flywheel, rods & pistons, and as the engineering shop have "misplaced" :roll: my stock valves I might as well look for a set of stainless ones.
I have had good work done by Smiths Auto in Silverton...
Bratjie
Post by Bratjie »
Do they do balancing, how much approx, my current engineer will assemble heads & so forth but do not do any balancing?
73 Beetle project
Bratjie
Post by Bratjie »
They can do it for ........ R 2100.00 :shock: :cry: :shock:
73 Beetle project
splitfan
Has thanked: 46 times
Been thanked: 26 times
Post by splitfan »
I have always used Dynamic in Edenvale , never had any issues just had a waterpumper bottom end ballanced worked out to less than R700-00 , rods,pistons,cranc,flywheel,pullys and clutch ect.
Bratjie
Post by Bratjie »
splitfan wrote:I have always used Dynamic in Edenvale , never had any issues just had a waterpumper bottom end ballanced worked out to less than R700-00 , rods,pistons,cranc,flywheel,pullys and clutch ect.
Wow I will definately give them a try, thx's,
73 Beetle project
Bratjie
Post by Bratjie »
Just an update,
Sending the rotating assembly to JHB for balancing on Friday, 1.25:1 rockerset will be here tomorrow, heads almost done & ready for assembly,
Picking up a coil driver & electr ign coil over the weekend for the electr dizzy. Still need A/F ratio meter, manual boost controller, BOV, 30mm oilpump, Dellorto jetting, and the odd fuel pipes and wiring etc,etc, almost there whew :shock: looks like I'm working backwards but funny, progress is made :D
With all this put together approx cost will be around 23K incl front disc brakes ( no g/box or susp mods included, no upgraded clutch assy, ) Wow, I've heard them say you can't properly budget for a build like this before and it's true.It's when you're done that you can get a clear picture :shock: , anyway I'm sure it wont end there and the fun will be worth the while :hangloose: :drunks: :hangloose: :drunks:
73 Beetle project
Bratjie
Post by Bratjie »
Excitement, excitement :hangloose: , 1.25:1 Rocker set arrived and sitting on the shelf smiling, now I'm just waiting for a Sleeve set a good friend of mine has given to me and it all goes for balancing, can't wait to begin assembly :D
73 Beetle project
Been thanked: 98 times
Portugal
Post by calooker »
I see it this way, whatever the initial budget was, DOUBLE it, it will be more realistic. :shock:
Bratjie
Post by Bratjie »
You are dead right, I never thought I'd end up here :wink:
73 Beetle project
Bratjie wrote:You are dead right, I never thought I'd end up here :wink:
you are not the first person to realise this....
Bratjie
Post by Bratjie »
Bit of an update, I received the heads back today, all shiny and good looking with new guides and shiny new valves, see the difference in spring lengths :shock:
Ported and polished by Wena (1st ever) but it came out very good, fitted the high rev valve springs and mocked up those schweet 1.25:1 Empi rocker set :hangloose: next are the moly pushrods and cam followers.
Now she's gonna rev like a mad woman :twisted:
73 Beetle project
Yes it all ads up so Quick that if you blink your Eyes then you have spend R8K just on machining on a Type 1 motor ask me as I just got the call from the Engineers that Elvis the 66 Squareback machining is done :shock:
