Hi all,
I'm keen to have the engine bay on my bud' modded...
I want to have the sides cut, tidied and flanges welded on resulting in removeable panels for my to get my plugs.
The current situation is dire due to the dual carbs in there...
Has anyone here done before? What's involved? Cost?
Thanks, Nic
Some custom metal work in JHB...
- Merlin
- Has thanked: 20 times
- Been thanked: 39 times
- 1972
Re: Some custom metal work in JHB...
Nic, its actually a verry simple mod that you can do yourself.
Go look under "how to" in hookys and also under "Miscellaneous" in "pannels".
http://www.hookyspanelshop.com/
http://www.thesamba.com/vw/forum/viewtopic.php?t=347716
Hope this helps
Hope this helps
- Merlin
Hey Shane,1972 wrote:Nic, its actually a verry simple mod that you can do yourself.
Hope this helps![]()
I've read up on it before, but I'm not a metal man and the thought of cutting my car is >very< daunting, hence my seeking someone with a bit more experience to do it.
Thanks for the links though.
Nic, I cut windows in my engine bay and put them back using good quality hinges. Have a look through my threads - you'll spot one above my oil filter.
- Merlin
Thanks Tony.Tony Z wrote:Nic, I cut windows in my engine bay and put them back using good quality hinges. Have a look through my threads - you'll spot one above my oil filter.
I hadn't considered hinging them...
I'll take a look.
N.
