jolas wrote:Hi Bugger, please will you take pics of your rotiserie, how you make it, etc, etc. What are they going to blast it with? I've has some bad luck with sand blasting, especially the panels. But it is without a doubt the best way to go. Are you going to put it in primer yourself?
I have also heard alot of stories about sand blasting that has gone wrong....
But it is true, sand/media blasting it first is the best then you know what you got to work with.
I did find one place in JHB that I was going send it for sand blasting too.. He quoted me R1200 to sand blast and R700 for MS primer or another primer that you can weld, etc with.. cant remember what it called. When I spoke to him, he said they use a very very fine sand to blast with so there "shouldn't" be any warping of panels....
But I didn't take it there.. decided to hang on a bit and see if BUGGOFF could do it.
This is the place details below..
http://blastandplant.co.za/services.htm
JRL BLAST <
jrlblast@absamail.co.za>
Johan Lubbe
0823271375
