67 Panelvan
- Phillip
- What model do you have?: 72 & 56 oval
Re: 67 Panelvan
Nice job on the steeringwheel,why dont u sand down the badge with fine paper and clear it aswell
- Donovan D
- Has thanked: 148 times
- Been thanked: 73 times
Re: 67 Panelvan
The scratches are pretty deep,Phillip wrote:Nice job on the steeringwheel,why dont u sand down the badge with fine paper and clear it aswell
Does anyone know where I can get runners and front seats?
Swivel seats will be great !
- fig
- Bus Driver
- Has thanked: 287 times
- Been thanked: 322 times
Re: 67 Panelvan
M183: Walk-through cab (Panelvan and Kombi - RHD)Ron&Gill wrote:As the Fig says, you could order your panel van or camper (post 1955) with M199 which gave you no bulkhead at all and a swiveling driver's seat.
Pre 1955, M057 would give you the cut-out bulkhead with a single post going up to the roof.
If you asked for M057 after 1955, you got wooden slats on your pick-up's load area... You must admit, it's almost the same...![]()
If you had a bus other than a camper or a panel van and you asked for M199... you got seat belt mounting points... eishDepending on which web site you look... Kombis would get you a swivel seat too.
But I think it would be a good idea to find out what M199 entailed. Just a saw and some swively seats, or did they actually build in some gussetts for reinforcements?
http://www.in2vws.com/images/images/M_O ... 200015.jpg
Walk-thru panels did not have the vents at the top rear of the load compartment.
- Klaus
- Has thanked: 13 times
- Been thanked: 11 times
Re: 67 Panelvan
I'm also looking for a few for my rack. I used the ones off rod holders found in most Auto stores as a temporary fix (lasted over two years so far with kayaks on the roof for long windy trips). Was an expensve exercise at around R60 a pop - probably more nowDutch_Diver wrote:I need 2 of those clamps too for my rack. If I find, I will buy 4 and send 2 over in the post.
- Donovan D
Re: 67 Panelvan
Started to fix up some holes,
Getting a bit pssd off, this was meant to be a quick cleanup(dirt/mud/grease) but the more I do the more the work piles on,
Behind the rubberizing
...Removed
New section
...Removed
New section
- jolas
- Has thanked: 393 times
- Been thanked: 173 times
Re: 67 Panelvan
ja it does'nt stop ! Looking good nevertheless .................
- Farhaad
- Been thanked: 2 times
Re: 67 Panelvan
i see you came right with the steering
is it a good idea to use clear on a flexible surface. is clear flexible?
- Donovan D
Re: 67 Panelvan
Yes, Im happy with the outcomefarhaad.sonday wrote:i see you came right with the steering.
I have no idea about the clear coat on flexible surfaces, Only way to know is to wait, maybe in a few weeks the paint starts breaking off
- Farhaad
Re: 67 Panelvan
lets hope not. if so then use a paint that does not require a clear coat and then by hand buff the shine up
- Donovan D
Re: 67 Panelvan
You guys like my "new" paint work ??
- Dutch_Diver
Re: 67 Panelvan
Which side?
- BUGGOFF
- Pushrod
Re: 67 Panelvan
Your bus is looking worse every day. but thats bound to happen before it looks better.
- Donovan D
Re: 67 Panelvan
Hey what you mean ?? Its a rat !!BUGGOFF wrote:Your bus is looking worse every day. but thats bound to happen before it looks better.
Just finished with my clearcoat on the dash, there is already dust specks
- What model do you have?: 72 Early Bay Deluxe
Re: 67 Panelvan
Hi there..
Is this an outrigger? Did you make ur own or buy it?
Splitz wrote:
Kuven Aramugam
E-Mail:
Contact #: 083 716 4455
Current Ride:2003 Golf 4 GTI
FRC - 76mm ATP DP and 63mm Wildcat Zorst - Forge TIP - Forge DV.
Project - '72 Early Bay Deluxe
E-Mail:
- Has thanked: 45 times
- Been thanked: 208 times
Re: 67 Panelvan
Was actually thinking the same thing.
Some sheetmetal parts like this one should be relatively easy to make.
