NLA
- Junior
- Pushrod
Re: Feeler: Ford V4 motor with Beetle adaptor plate
I cant believe that I'm actually saying this but I wouldn't mind putting a v6 into my bug could be lots of fun
How much would that adapter plate cost? How much do you guys thing you would have to spend on a standard 1600tp to get it to have the same amount of power? And surely a V6 wont mind going to 4000rmp with out mods?
- Junior
- Pushrod
- fig
- Bus Driver
- Has thanked: 287 times
- Been thanked: 322 times
The Ford V6 is a LOT heavier than even a Type 4 ACVW engine.
Also ask yourself what happened to all the Ford V6s; there aren't many around any more. Excessive camshaft wear and non-availability of parts has sent most of them to the scrapyard.
- Dazz
- Oil Cooler
- Has thanked: 2 times
- Been thanked: 4 times
yip...the engine with the lines on the tappet cover is the uprated heads...more power and didnt have an issue with noisy tappets and cooling
Measure twice CUTonce.
1975 Kombie
1979 Kombie
W203 C320 CDI
'68 Austin Cambridge A60
Looking for a kombi project
1975 Kombie
1979 Kombie
W203 C320 CDI
- Ron&Gill
- Been thanked: 21 times
That V6 makes 100kW. Our 2270cc make the same, if not more, if set upright. Mine makes 106kW.
- Dazz
- Oil Cooler
Ron&Gill wrote:That V6 makes 100kW. Our 2270cc make the same, if not more, if set upright. Mine makes 106kW.
What are you running?
and what was the cost of building your monster?
1975 Kombie
1979 Kombie
W203 C320 CDI
1975 Kombie
1979 Kombie
W203 C320 CDI
- Ron&Gill
http://www.aircooledvwsa.co.za/viewtopi ... 23&t=10290
044 heads, engle 120, 44mm IDFs, 96 pass oil cooler, 009 dizzie, Porsche shroud, full flow oil system, 8 doweled lightened fly wheel, Kennedy clutch. Such like. Lots of machining for the sleeves and crank.
I can't remember what the motor cost... lots...
Tony? Ballpark a number?
It is now in normal T1 tin in Gill's bus, in which config it is a lot cheaper. The Porsche shroud is now on the turbo motor for the Razor.
- Dazz
- Oil Cooler
Ron&Gill wrote:http://www.aircooledvwsa.co.za/viewtopi ... 23&t=10290
I can't remember what the motor cost... lots...Tony? Ballpark a number?
now if you look at that ad...you would see that its a totally refurbed motor for R4500 ...im not saying go put a V6 in an ACVW...im just saying that for such an old engine it was strong reliable.....in their day.
1975 Kombie
1979 Kombie
W203 C320 CDI
1975 Kombie
1979 Kombie
W203 C320 CDI
- slak
- Has thanked: 7 times
- Been thanked: 32 times
it is a 1996cm motor with 76kw 162nm
and sounds like a harley in a beetle because u cant fit much of an exaust
space is minimal only the crank heads and block is different from a normal
essex v6
one of my friends had one it ran nice bur is a bit rear heavy not good
for handling
essex v6
for handling
U Only Live Once Right !!!
- Ron&Gill
My boet's father-in-law had a 2 litre V4 in a beach buggy (same shape as Big-Toe). I drove it a couple of times, it was fun. Don't know much more about it.
- Junior
- Pushrod
But the fact of the matter is when you put a water cooled motor in any air cooled its not longer a air cooled car so for now I am still going to stick to my trust worthy air cooled motor with a few extras to make it a little more fun even if it cost 4 times the price.
- slak
i.ll second that no wc in ac
40 to 60K depending...Ron&Gill wrote: I can't remember what the motor cost... lots...Tony? Ballpark a number?
- CooP
- Clutch
- What model do you have?: '71/72 Hybrid Westy
- Has thanked: 13 times
My mum had a V4 Corsair when I was at school. What a heap of
it was, constantly breaking down, leaking all sorts of fluids, making strange noises and smoking even more than Mum. The only interesting parts of the car were the 8-track player and the slot under the dash for playing 7" singles - really cool and unseen these days. I wouldn't recommend the engine though - Ford stopped making them for good reason.
Size does matter
Went to go and have a look at the engine this past weekend, what a rubbish of an engine.
Was standing outside for many years, probably seized as It doesn't want to turn over.
I decided not to take it, got a complete Golf 2E motor instead
