'63 Type 1 aquired today :D
ZeroAxe
Drive Train
Re: '63 Type 1 aquired today :D
Post by ZeroAxe »
Yup, that is the life of Aircooleds. Keeping them going :lol:
VW Enthusiast
sarel.wagner
Post by sarel.wagner »
Pulling the motor to get at the Release fork, it moved and clutch stopped working...
Also managed to get some 6V light bulbs :)
Rgrds
sarel.wagner
Pulled the motor this morn. Found the cir-clip tired and it got out, hence the shaft moved. More worrying is that the 2 clips keeping the release bearing in its place is nowhere to be found, wtf :huh:
Need 2 of those clips, chances are a new release bearing and a new cir-clip for the shaft.
Pressure plate bent, is this ok?
Rgrds
JamesD
Been thanked: 20 times
Post by JamesD »
Those release bearings are hard to find, so just a warning. And yes, i would replace the pressure plate. if its bent then it will affect the balance and could cause uneven pressure on the clutch.
From fastest to slowest:
'75 SP 1600 with a few mods
lowlight
Post by lowlight »
bought one last week in Pta R175 I think. Midas across Jakaranda sentrum. No clips with
Volkspares PTA has them at R200-00.
sarel.wagner
:D Fanx Blitzie for the :zhelp: You da man! :hangloose: Volkspares got stock :) Picking up later 2day...
Rgrds
Klaus
Post by Klaus »
Hey Sarel - again awesome ride :hangloose:
- Hijack - When you gonna put up some of the awesome pics you took at the Drift ?
sarel.wagner
Fanx bro :) did put up on the pictures post for KKKAK, but here is a link to all, full size :D
http://www.flickr.com/photos/sarel_wagner/sets/
Rgrds
sarel.wagner
Busy fixin n replacin bits while the motor is out...
Sandy and media...
Painted tinware, genie housing cleaned up with sodabrade media :)
Works a treat....
Rgrds
