Right then, we're making progress!! My new engine cowl has arrived from Mr FFF (Thanks again G, looks great!) I'm still missing tin for the engine bay, but i'll post something in wanted for that.
I've started vibration proofing the floor (Flashband it is) and popped past Sondor to collect some high density foam for the firewall and rear section. At R89 for a 2 x 1 m sheet, i dont really care if it doesn't work. Also started the finer things, below shows the rubber for the bonnet in, came out nicely actually. brake reservoir is mounted and i popped the carpet in just for kicks
I'll take it to get a gas shock when it's on the road.
Also got the brakes sorted, thanks to Dave R. Quick pedal adjustment, modification to the pushrod (lengthened a tad) and i now stop pretty quickly. I'll give it some time to bed in the new brakes front and rear, and i'll adjust again just for good measure.
I've decided Santa is dropping off a car polisher for being such a good boy this year.
Also sorted most of the wiring again (At least everything works again, except the hooter) i'll still take it to an autolec, just to sort out the cobwebs under the dash.
So all in all it's looking good. will post pics as i go along, but things are speeding up now.
