Quick update.Took out the engine. Starter bush shot. Problem 12V starter on 6V gearbox. Inside diameter different between 6 and 12V. Is the outside the same for the 2?
Brakefluid but need to open then will tighten it again preperly.
Stil struggle with idling. if you play will the accelarator it runs but as soon as you keep the peddle still it dies on me. . New rubbers seals no leaks. Its 34 carb
Got the problem I think. Struggle the last few "months" it feels. Then decide to phone Dirk in Pta the vw man explain to him the problem and he recomend most of the things I have done already. Then he said I should check the idling jets on the right hand side of the carb all clean. Then he recommend that I should loosen the idling jet by 1/8 of a turn more or less and see if it will idle. Its idling. Problem is wear on the thread and then it turns in to deep and block the hole. I made up a wascher and tighten it so that it wont rattle loose. Idling nice and I can even set he idling speed as it should be. Will check it tomorrow again, just incase.
Pics for Blits
cuboard by the door almost finish need the back, bottom and golden trim around the top(where can I find that?)
lowlight wrote:Still busy on the cuboard got varnish on Saterday, need some more attention here and there.
Everything connected started the bus starter works but still dont want to idle even if you step on pedal and hold it stil.
Bought a few things for the other busses.
looking good LL
is that a bumper mounted reverse light with an "eyebrow"
if it is, pleez let me know where i could find one. have been looking for something like that
Took a few(4) years to gather these things for the 57. When ever I see a place with old spares. I keep a look out for some thing I can use. Best bet will be old car clubs and swop meets.
