Identify the tool
- Been thanked: 24 times
Identify the tool
This is a general question.
What is this tool and how is it used?
This is a copy of an original that came through my hands some time ago.
Re: Identify the tool
well not knowing its true size makes it difficult , looks like it could fit into the fly wheel bearing to check ?????????? something !
- vader
- Has thanked: 9 times
Its a harmonic harmonizer for the Anti-Matter Flux Conversion Coupler in the Mk 3 Warp Drive. Not to be confused with the lavatory reverse suction backwash tool which looks almost the same but doesn't have the hole in the hammer like head....
Hope that helps....
Hope that helps....
- eben
- Site Admin
- Been thanked: 54 times
- 4agedub
- Has thanked: 4 times
- Been thanked: 13 times
Maybe a fridge door handle?
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
Do you know and just quizzing us or are you genuinely asking?
- Thumper
- Has thanked: 6 times
Its two materials, Aluminuim and a machined steel insert held with a grub screw. Looks like a tool for a very specific purpose thus limited numbers of this item.
The steel part fits into another component that locks it in, but it can still turn 360 degrees on the spindle.
I think its a........what the heck, I think Vader is correct. However the harmonic harmonizer for the Anti-Matter Flux Conversion Coupler in the Mk 3 Warp Drive is known to be made of Titanium and Driudium Alloy from Spretea14. This looks like a cheap copy. (I wont fit on a flux Conversion coupler in my neighbourhood)
- dubster
- Been thanked: 3 times
Old school can opener?
1974 1300tp type 1
kart kraft 1717cc buggy
- splitfan
- Has thanked: 46 times
- Been thanked: 26 times
I think it fell off the hubble telescope......
- 1972
ok i have seen one of these before it is used to cut glass in a circular shape hehe like in the spy movies but yours seems to be missing the blade and the suction cup
http://www.fredaldous.co.uk/shop_images ... 770002.jpg
have no idea what it is lets start over where did you get it from?
Oh, I know what it is and how to use it.
And no Vader it is not an illuminating devise for dark and smelly crevices. No it is not made from depleted uranium
Yes it is a Volkswagen Beetle specific tool for a special and important task.
We have a responibility to pass knowledge and skills to the next generation......
I was lent the original by a guy that was trained in the factory in Wolfsburg in the days when mountains were small and rocks were still soft and I had a copy made.
- fig
- Bus Driver
- Has thanked: 287 times
- Been thanked: 322 times
I can't see photobucket pics at work.
How about appending it as an attachment to this thread, so I can play too ... pleeeez.
BAB, it is about 172mm long, on the shaft end it is about 32mm wide and on the flat side 30mm wide.Bad Ass Bob wrote:well not knowing its true size makes it difficult , looks like it could fit into the fly wheel bearing to check ?????????? something !
- beetlepower
- Twin Port
- Has thanked: 3 times
- Been thanked: 28 times
aligning gear selector or something on the front suspension?
0828378801
@reubenvn on twitter
0828378801
- eben
- Site Admin
