T4 1.7 i into late bay dc
BUGGOFF
Post by BUGGOFF »
Hi guys, im going to fit this motor to my dc, just want to know if it will be best to use the feul injection or carb/s? And whether the wiring for the f.i. is difficult to sort out? Thanks Ferdi.
BUGGOFF
Re: T4 1.7 i into late bay dc
Post by BUGGOFF »
(bump)
I've never used that type of FI but from what I heard you need to make sure you have ALL the parts.. Also I think you will need to have a look at the fuel pump setup as some of them requires a return to the tank.
BUGGOFF wrote:Hi guys, im going to fit this motor to my dc, just want to know if it will be best to use the feul injection or carb/s? And whether the wiring for the f.i. is difficult to sort out? Thanks Ferdi.
Why don't you source Microbus 2.1 EFI and run it with that? It has been covered on the forum before, search for it....
It definitely won't be difficult to do :wink:
Get one of those 36 DCD Webber manifolds or build one and run that you will not be dissapionted
BUGGOFF
Post by BUGGOFF »
So i take it that the stock fi is not that good?
The stock Fi is like a Donkey with a Maclaren Coverall
