The Holy Grail found: VWSA paint & upholstery codes
Has thanked: 284 times
Been thanked: 321 times
Re: The Holy Grail found: VWSA paint & upholstery codes
Herbie wrote: Tue Oct 27, 2020 2:18 pm
beetlepower wrote: Fri Jun 22, 2018 12:15 pm
No Beetle page for 1971?
Hi BeetlePower. I think I may have solved this mystery. If you look at the cards under 1971, right at the bottom of the cards, the print code is D30396. When looking at the cards under 1972 the print code is D41017, with the exception of the last card listed under 1972 which also carries the same print code as the 1971 cards. I think in the scanning it got mixed up...a very easy mistake and no offense to you @Fig Also look at the top left corner, the 1971 cards has a screw in pin keeping the cards together and the 1972 cards a little piece of rope, except for the last card. So I think your missing 1971 Beetle card is there under 1972.
N
Thanks for this Herbie, and well spotted! I only read this post now. I've edited the 1971 and 1972 posts to correct my error.
