1976 kombi gearbox swop
Bay window kombi
Post by Bay window kombi »
Hi guys
I need some info.
Can you swop the nose cone and gear selector from a 1976 kombi 091 gearbox with the 1980 T25 gearbox? And also swop the hydraulic clutch setup to the cable setup?
Basically fit the T25 gearbox (091) to the 1976 kombi?
sean
Has thanked: 63 times
Been thanked: 227 times
Re: 1976 kombi gearbox swop
Post by sean »
Can you please explain why you want to do such a thing when you can simply just install the correct box as it came out with?
Guest
Post by Guest »
Hi its the only box i have available that is running
Guest
Post by Guest »
And im up for the challenge if it is doable.
And the old gearboxes are becoming more and more expensive :(
sean
Post by sean »
I would suggest taking that time and fixing the existing correct gearbox. You will also then have the T3 box for a T3 when the time is right.
What you don’t want to do is bastardize 2 gearboxes and not have 1 that works at the end.
What is wrong with the bay gearbox?
Guest
Post by Guest »
Thank you Sean.
It broke the teeth on the axle part inside the box
sean
Post by sean »
What motor is in this bus?
Guest
Post by Guest »
The Ford v6 was in but changed to the original 2l.
sean
Post by sean »
Yes, typical damage from a ford V6. Glad you removed it to avoid more damage.
Replace the crown and pinion.
Last bumped by Anonymous on Tue Aug 04, 2020 10:13 am.
