CB Performance Parts available in South Africa
Get your parts here
Has thanked: 191 times
Been thanked: 487 times
CB Performance High Performance and Stock/OEM parts available.
Limited stock, more arriving regularly.
Contact me (Tony) on 0833418937 (whatsapp friendly) or pm me on this forum
Wir sprechen Deutsch
Fan dress-up kit/tinware
Oil filler breather box
Image Image
36hp style fanshrods, with external "doghouse" style cooler (later 1600 engines)
Image Image
Full flow oil pump covers
Wide Glide oil sumps - 1.5L and 2L extra oil capacity - thin and wide, minimal change in ground clearance
OEM Distributor O-rings
New rocker arm nuts / valve adjuster nuts - Heavy Duty and thin (no more rounded off nuts and slipping spanners
New OEM oil filler cap
HD, long life steering coupler
Porsche Style Valve adjuster
[Image
Rocker spacer, shims and adjusters
New Stock style gland nuts (flywheel bolt), new stock washers (Wavy / Belleville) and HD Racing Galnd nut with oversized washer
Oil filler necks - stylish and easier to use than stock.
Oil change kit - includes gaskets, new sump plate with drain, new drain plug and new mesh filter
Cam gears for performance/racing cams
Early bug horn covers
New oil coolers
Barrel shims for stock size barrels and oversized (90.5mm, 92mm and 94mm piston sizes)
Titanium valve retainers, Cro-moly valve retainers, HD lash caps (wear caps - protects valve head from wear) and rocker shim packs for solid rocker shafts
New CB performance 044 heads, 94 bore, 42mm inlet valves, 37.5mm exhaust valves, dual HD valve springs, Cro-moly retainers. Unported
H-Beam racing con rods, various lengths, VW and Chevy journals
Clevite Rod bearings and Silverline Dual thrust cam bearings
Type3 style lower cylinder tin
Pushrod tubes - 40hp, stock 1600, Windage, racing, stainless steel, and Silicone Pushrod tube seals
Engle W100, W110 and W120 camshafts and Engle lifters/followers
Rhino engine/transmission mounts
Oil pumps with filter mounts for early and late cams (stock and performance 1600 style cams)
Oil filter mount for remote mounting of oil filter on full flow cases
Wafer adapter - mounts between oil filter and its mount to allow oil to be sent to external cooler
Quick shift kit - made from metal, not plastic like other brands
Billit oil dipstick
Serpentine belt system
Sand seal pulley (left) and billit aluminium pulley (stock style with degree markings) on right
Cro-moly head stud kits with new (thick) washers and HD nuts - 8mm
Been thanked: 539 times
Re: CB Performance Parts available in South Africa
Hi Tony
Will take the following please;-
2 off Oil change kit - includes gaskets, new sump plate with drain, new drain plug and new mesh filter
2 off Quick shift kit - made from metal, not plastic like other brands
2 sets of rocker arm spacers for type 4 heads (need to lift rocker as arm touches spring cap).
Plus Postnet
Did you morgage the house???? Some serious money spent.
I'm officially a dealer now.
Even with the exchange rate at R17:1 when I placed this order, my prices have come down
I've got plenty more, but not worth photographing.
AlanH
Has thanked: 117 times
Been thanked: 86 times
Germany
Post by AlanH »
Cool, will be in touch when the time comes.
Wanted parts:
Left sunvisor
Sink faucet
Donovan D
Has thanked: 148 times
Been thanked: 73 times
Post by Donovan D »
That is some very nice stuff there Mr Z !
Eugene
Has thanked: 59 times
Been thanked: 65 times
Post by Eugene »
Donovan D wrote: Thu Nov 26, 2020 7:44 am That is some very nice stuff there Mr Z !
:lol: :lol: :lol: :lol:
acpaterson
Has thanked: 80 times
Been thanked: 131 times
Post by acpaterson »
Hey Mr zzzzz, how u bru...
Pls pm me the cost of the oil filler with the Nozzles?
Also if you have nozzles for the Tappett covers? otherwise where I could find locally? Would like to have the system balanced properly, vs just a pipe going into the top of the one air filter.
thanks bud
regards
Alan
Hi Alan
The ones in the picture below cost R600 for the straight filler and R820 for the angled filler. In your bus I'd recommend the straight filler.
In my bus with the 2100cc engine, I use the straight filler with no more vents as they are not needed if you keep the revs below 4500. I've had no crankcase pressure problems.
Tony Z wrote: Thu Nov 26, 2020 4:08 pm Hi Alan
The nicest thing about the above filler necks is that the "Standard" coke bottle top or 500ml water bottle top fits and seals perfectly inside the neck. You can cut a funnel out of a plastic bottle that you have lying around and it seals nearly leak free for a great and easy way to add oil (unlike stock). I stock these because they work so great.
acpaterson
The first one, the collector box with the nozzles..
acpaterson
Arno (Andreno) likes to vent the oil breather into the top of my air filters on the ICT's, and it gets messy in there.. So, I want to do this better.
acpaterson
Or, what do you suggest?
(I took Winston back to him 2 weeks ago for a check up etc (5 years) since he installed the motor, and it was a bit oily. He put in another crank pulley, and took the the top of the oil breather back into the top of the one carb filter.. But it doesn't sit properly, and it's been siliconed etc.. so it's torn and looks messy..
acpaterson
Tony, can I get the standard oil filler top off without having to remove the fan housing etc? It looks like it's just a screw on, am I right?
the stock vent went into the air filter for emissions purposes. You reburn the gasses coming out of the case.
There is nothing wrong with running it into your filters, but you say it is getting very dirty in there, where is this dirt coming from? There shouldnt be oil coming out of this pipe.
You can get the stock oil filler off with the fanhousing in place. You need a special tool or a home-made screwdriver to get the nut off. Yes, it is screwed on.
This baffled vent/filler is R1725. Yes, it does have baffles inside.
