Billet VW Wheel Adaptors
Get your parts here
forcecooled
Post by forcecooled »
Hi All,
I am selling a set of four wide five (205mm Pcd X5) to 130mm Pcd x4 VW wheel Adaptors,
So you can now fit it your EPMI 8 spoke or other 130mm Pcd mag wheel set .
They are machined from solid billet and are drilled and tapped for 100mm x 4 Pcd wheels as well .
There are studs fitted in the 130mm Pcd mountings.
Undercoated machine grey, and are in as new , perfect condition.
Suitable also for fitment to the 5 Bolt Kombi drums with the larger wheel bolts .
A new set of 4 of these from the machine shop will set you back around R 2300-00 .
Price for this set - R 1500-00
If interested, call or message me and I will send you a photo.
- Bill Noble
072-110-2643
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Re: Billet VW Wheel Adaptors
Post by Terry Phillips »
PM sent thanks.Not what I was after thanks Bill.
