Beetle parts for sale
Get your parts here
beetle786
Camshaft
Post by beetle786 »
I've got these parts for sale and a lot more .
Or trade it all for a running bug .
Or swop for something good I might be interested in .
Vw Beetle Gearboxes /engine Spares ,cylinder heads . engine tin , fan housings , alternator pedestal , alternators ,starters, petrol flaps . Fuel gauges ,1x 60,s model mechanical gauge with sender unit , fenders ,headlights ,tail lights /housings . Indicators . Rubber seal kit new . Heads lamp rings ,std / 4 into 1 exhaust system , front H beam , front and rear drum assemblies , new brake cylinders . Alternator parts , turn signal parts , speedo clocks , Door panel clips , bolts and nuts /clips /switches . Brake master cyl brake fluid bottle , brake cylinders old /brake star adjusters and springs / rubber brake pipes . Rear torsion bars with spring plate .carpet set with thick rubber padding ,front and rear bumpers . Fuel pumps , carburetors , distributors ,intake mani faults single and twin . Engine Gaskets , gearbox spigot shaft seal , gearbox mounts , rims with tires , 2x hub caps , some old rubber seals door handles inner /outer some have keys engine lid locks matching set , door panel tray etc ...
All parts are used unless stated they new .
Pls ask if you looking for anything specific then will see if I've got .
PM me if interested .
What's app or call 0784275792 for pics .
Thanks guys .
4029
64 Notchback
Has thanked: 78 times
Been thanked: 37 times
Re: Beetle parts for sale
Post by 64 Notchback »
Hi
Price for the carpet set please
beetle786
Camshaft
Post by beetle786 »
*Vw Beetle Gearboxes x3 (1 gbox working order .1 gbox disassembled all running gear ,1 gbox only shifts into reverse )
*engine Spares cylinder heads . *engine tin
*fan housings
*alternator pedestal
* alternators and spare parts .
*crank and alternator pulleys ,shims .
*starters
*fenders
*rear valence .
*engine lids .
*headlights
* tail lights /housings
*Indicators
*Rubber seal kit new
*Heads lamp rings
*std / 4 into 1 exhaust systems
* Front suspension
* front and rear drum assemblies *new brake cylinders
* turn signal parts (indicator switch)
*speedo clocks
*Door panel clips
*bolts and nuts /clips /switches .
*Brake master cyl brake fluid bottle *brake cylinders old /brake star adjusters and springs / rubber brake pipes , steel pipes .
* Rear torsion bars with spring plate *Carpet set with thick rubber padding .
*front and rear bumpers .
*Fuel pumps
* carburetors + spares
*distributors
*intake mani faults single and twin . *Engine Gaskets
*gearbox spigot shaft seal
*gearbox mounts *rims with tires
*2x hub caps
*some used rubber seals
*door handles inner /outer with keys engine lid locks matching set
*door panel tray etc ...
*steering columns
Price Neg .
All parts are used unless stated (new ) .
Pls ask if looking for anything specific.
E-mail if interested .
Thanks guys .
4029
beetle786
Camshaft
Post by beetle786 »
64 Notchback wrote:Hi
Pm sent
4029
beetle786
Camshaft
Post by beetle786 »
4029
beetle786
Camshaft
Post by beetle786 »
4029
peterhulley
What model do you have?: 1970 1500 Beetle
Post by peterhulley »
Hi, would you have a 1970 Beetle steering with hooter ring maybe
Thank you
Peter
Jessescott
Post by Jessescott »
hi, im looking for a carpet set for my 1970 beetle 1300.
also a floormat set if you have.
please send some prices and details
Regards,
Jesse
butzi
Post by butzi »
H
I am looking for steering shaft bearing and bush for a 1971 bug
Butzi
AlanH
Has thanked: 126 times
Been thanked: 86 times
Germany
Post by AlanH »
That post was from 2017.
Don't think you will get joy.
Wanted parts:
Left sunvisor
Sink faucet
