Beetle 1300 Single Port Heads Headache
Has thanked: 191 times
Been thanked: 487 times
Re: Beetle 1300 Single Port Heads Headache
the high rpm "break in" is for a new cam
rev it once or twice to make sure it gets a little oil and then drive
73type2
Has thanked: 141 times
Been thanked: 100 times
France
Post by 73type2 »
Great, thanks.
73type2
France
Post by 73type2 »
I decided to replace the leaking main and transmission seals while the engine is out.
73type2
France
Post by 73type2 »
If you don’t have the original Beetle spark plug wires, or are cheap like me, you can use Bougi wires and add a little rubber disk to seal the hole:
73type2
France
Post by 73type2 »
Another headache for me is to find a properly fitting oil breather hose. I wanted cloth covered 1/2inch hose, but couldn’t find it, so I resorted to using general purpose hose. The problem is that it’s too stiff and puts too much tension on the airfilter fitting. A plastic irrigation elbow fitting sorted it out:
Camshaft
Been thanked: 107 times
Post by Haans »
nothing wrong with that boet !!!! boer maak n plan that's what it's all about
haans
